To do what?· To test outputs all you need are as many resistors and LEDs as you may want to verify simultaneously.· To test inputs all you need are two resistors and a switch for each as you reckon appropriate.
·· The minimum components needed to create a functioning Stand-Alone BS2 are the Interpreter, EEPROM and Resonator.· This does not include a facility to reprogram it and requires a regulated 5V supply.· I hope this helps.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support csavage@parallax.com
