BS2sx progaming serial port stop working while GPS is connected
I’m having some terrible issues connecting a Garmin eTrex GPS to my Stamp Module. ·I’m connecting the GPS just using pin 2, TDX and Ground, initially I interface with a Pharos 360 GPS without problems but when I connect the Garmin unit the programming port just die, The PC is unable to recognize the Stamp until I disconnect the GPS unit, then I can transfer data again from the PC to the Stamp. ·I try connecting the unit to pin 3 and 13 with the same results. There is something an I doing wrong?
My stamp is using a 8 VDC connected to Vin and Vss, The GPS is using just gound connected to Vss and TXD . BTW I try just connecting the GPS using the two pins to the PC and I get all the data expected.
I more note, the same issue happens using a BS2sx and a BSP2
Thanks for helping!
Thanks for helping!
Did you put a current limiting resistor between the Stamp and the GPS's TXD pin?
