source code for keypad through lcd display HELP!!!!!
Hello, im new to this,· i have a ls 204-25 display with keypad attached, i am comunicating well with the display but cannot see the keypad doing anything, dont even know how to test it,·· i placed these commands in the editor
SEROUT 1, 84, [noparse][[/noparse]254]······ 'Command Prefix
SEROUT 1, 84, [noparse][[/noparse]66]······· 'Backlight ON command
SEROUT 1, 84, [noparse][[/noparse]2]········ 'Setting the number of minutes to be on
· SEROUT 0, 84, [noparse][[/noparse]254]······ 'Command Prefix
SEROUT 0, 84, [noparse][[/noparse]65]······· 'key AutoTransmit ON
SEROUT 0, 84, [noparse][[/noparse]85]······· 'key Debounce time command
SEROUT 0, 84, [noparse][[/noparse]8]········ 'key Debounce time nominal of 52ms
i am guessing there needs to be a serin command·· but i have no clue how to write it,·
serin 1, 84, ???????
i am trying to use the keypad for a password program·,
' {$STAMP BS2}
' {$PBASIC 2.5}
DEBUG"Micro Board Self Diagnostics" , CR
PAUSE 2000
LOW 14
LOW 15
'data directives
Password··········· DATA··· "33722"
'variable declarations
index······· VAR·· Nib
temp········ VAR·· Byte
userentry··· VAR·· Byte(5)
'initialization routine
GOSUB check_password
'main routine
DEBUG CR, "complete"
END
'subroutine
check password
check_password:
· DO
· DEBUG CR,"Enter Password"
· DEBUGIN STR userentry \5
· FOR index=0 TO 4
· READ password + index, temp
· IF temp <> userentry(index) THEN EXIT
· NEXT
· IF index <> 5 THEN
· DEBUG CR, "password incorrect"
· ENDIF
· LOOP UNTIL index=5
· DEBUG CR, "accessed"
·SEROUT 0, 84, [noparse][[/noparse]254]······· 'Command Prefix
SEROUT 0, 84, [noparse][[/noparse]88]········ 'Clear screen command
SEROUT 0, 84, [noparse][[/noparse]"·· Mainframe Online "]
SEROUT 0, 84, [noparse][[/noparse]"· Tracking System..."]
PAUSE 2000
SEROUT 0,84,[noparse][[/noparse]254]
SEROUT 0, 84, [noparse][[/noparse]"·· Initilize I.R."]
dont no where to put these..
·SEROUT 1, 84, [noparse][[/noparse]254]······ 'Command Prefix
SERIN 1, 84, ???????????????????????????????????????????????????????
thank you for looking at this...
' {$STAMP BS2}
' {$PBASIC 2.5}
PAUSE 2000
LOW 14
LOW 15
'data directives
'main routine
END
'subroutine
check password
check_password:
· DO
· FOR index=0 TO 4
· NEXT
· ENDIF
PAUSE 2000
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
I ran the file but nonething happens,· my out is pin 0···· in·· pin 1
do i need to change them in the program,·· i dont really undertand the code i just cut and paste what works,
i do undestand somethings· serout 1, 84, [noparse][[/noparse]""] etc.
I dont even know if the keypad is hooked up right,· i used a "flat" harddrive cable to connect the keypad to the lcd,· seems like i could test it to see if im getting an input.....
Dave
Dave Andreae
Tech Support
thank you SO Much,
Ill try to dissemenate the information thanks again,,
Charles Cline
C.E.O.
I.S.S. Inc.
