capacitor value
Mike W
Hello to all
I have toasted the small capacitor in my parellax standard servo. It is the capacitor on the top of the board right in front of the potentiometer.
It is red, polerized, with the numbers 22 and 10 printed on it, the 22 is on top the 10 is below.
I think that this is a 22 nF rated at 10 volts but i'm not sure. If anyone could help me I would appreciate it, I think that this is the only damage I did to the servo.
Mike W
Mike W
Well well, I'm seeing things, three of them.
-Stanley Blystone
· Also, it is most likely 22uF, not "22nF".
Thank you for your responce. There was no checking this capacitor as I turned it into a tiny piece of charcoal with two wire leads leading from it. But I supected it was a tantalum cap, and from searching my Mouser catalog the discription led me to·believe it was·a larger value (22u not 22n) than I first thought.·You guys have backed up·my suspections more than likely with experience and knowledge, as compaired to the guessing I was doing.
Thanks·again
Mike W
-Rule your Destiny-
--Be Good. Be Bad. Be Provas--
HAHAHAHAHAHAHAHAHAHA!!!
I 've seen many use them in the output of amplifiers like LMV721 and LM833!!!
-Rule your Destiny-
And no, capacitors can't 'reduce' voltage.
A bit of fun reading:
http://en.wikipedia.org/wiki/Capacitor
Don't visit my new website...
-Rule your Destiny-
