Writing data to a text file — Parallax Forums
SheldonSheldon Posts: 3
edited 2006-06-09 07:07 in BASIC Stamp
Im using a basic stamp to read a POT how do i store thre readings in an external file· or a database?
  • Bruce BatesBruce Bates Posts: 3,045
    Sheldon -
    You can output the data that you need to save via SEROUT (asynchronus serial output). The "receiver" can be any of the following: StampDAQ, Hyperterminal, Procomm or other communications utility program. If you want to eventually plot the data, StampPlot is also available, to plot it immediately, in real time.
    StampDAQ - A generalized data aquisition program, written by Parallax, and available on the Parallax web site here:
    http://www.parallax.com/html_pages/downloads/software/software_stampDAQ.asp
    Hyperterminal - A Microsoft utility supplied with all versions of the Windows Operating System. Hyperterminal can capture incoming data and create a standard disk file from it, given the proper parameters. Other operating systems have similar utilities.
    Procomm (and others) - Nearly any "decent" communications utility program will have at least the same capabilities as Hyperterminal (see above). Check your favorite shareware/freeware download site.
    StampPlot - An excellent graphing utility, supplied by Martin Hebel, which accepts asnychronous serial input from a PBASIC Stamp, and creates a real time graph, according to the users specifications, right on the PC screen. StampPlot can be found here:
    http://www.parallax.com/html_pages/downloads/software/stamp_plot_pro_info.asp
    Bruce Bates
    <!--StartFragment -->
