Servo controller down
hello!
I`ve built a steering system using two servos, a servo controller unit and a BS2. Everything worked perfect yesterday, but nothing works today!!!
The problem is that I can`t control the servos anymore, By placing 5 volts at the BS pins. I know that I get power to the BS and the pins, and there is no connection problem between the servo unit and the BS.
What makes it even more strange is that one function still works, but no else function.
I`ve tried reloading the software, restarted both units, reseting them, checked connections and so on. Nothing helps and I don`t get it, how can it break without me even·touching it!?
This is not intended to be a solution to your problem, but rather a method for a logical troubleshooting approach. When I'm suddenly faced with an all-of-a-sudden nothing works situation, the first things that come to mind are: 1) inactive power supply, and 2) loose or dropped/missing ground connection.
Either of those conditions will pull the plug on the entire project in short order. Condition 2 also includes the case where there is supposed to be a common ground between two (or more) attached sources of power (Ex. Stamp power supply and servo power supply) and the common grounds have become disconnected for some reason.
Second, I might consider the perpetual reset scenario. Here, the Stamp begins operation, performs a few menial tasks, something causes the Stamp to go into reset mode, the Stamp resets, and the process begins all over again with nothing productive being done. However, from the "outside" it looks like nothing at all is occuring, The way to detect that this situation is occuring, is to add the following as the FIRST line in the program:
DEBUG "Program Starting"
That should ONLY display ONCE during any given iteration of the program. If you see it appear more than once, the Stamp is being RESET!
Let us know the results of checking those things, and we'll go on from there.
Bruce Bates
<!--StartFragment -->
When I turn power on, the servos goes to there home positions (which they should), and then the throttle servo starts to turn as if I would pressing accelerate (which I don`t!), and there is no power·to this pin when this happens.
I`ve attached my program, maybe it could help...
'{$PBASIC 2.5} Sdat PIN 15 ' Serial Data I/O pin Baud CON 396 ' Constant for 2400 baud buff VAR Byte(3) ' temporary variable FindPSC: ' Find and get the version DEBUG "Finding PSC", CR ' number of the PSC. SEROUT Sdat, Baud+$8000, [noparse][[/noparse]"!SCVER?",CR] SERIN Sdat, Baud, 500, FindPSC, [noparse][[/noparse]STR buff\3] DEBUG "PSC ver: ", buff(0), buff(1), buff(2), CR STOPHave you checked to be sure that both of your switches are working?
Other than that, like Bruce said, you should fill your program with debug statements so that you can see what is going on inside your loops.
My money is on a loose switch connection.
-Tristan
·· Are you trying to power the servos from a BASIC Stamp I/O pin?· Please post a wiring diagram of your circuit so we may try to help you troubleshoot it.· Thanks.
csavage@parallax.com
You won
It´s all working again!
Thank you for your help!
