Lots of strange data
I've been getting a lot of strange data. I went back to·basics, and wired a simple pushbutton circuit.(onee wire to Vdd and one to P0. I used this code:
As soon as i click run, I get a ton of a's. So I disconnect Vdd. And I still get A's, even when I restart. Perhaps something with my circuits are wrong,·because this has happened a lot lately.
I tried this on a BOE and a home work with no luck.
' {$STAMP BS2} ' {$PBASIC 2.5} ' {$PORT COM4} DO IF (IN0 <> 0) THEN DEBUG "a" endif loop
·Somebody said...
-Never Underestimate the power of human stupidity.
A pushbutton wired to P0. That is it. I used the same code as above. As soon as I touch the pushbutton, the aa's appear, but now they will go away when i release. The strange thing is there is no Vdd attached!
The pins are very sensitive and they are picking up electrical noise caused by your body.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"I reject your reality, and substitute my own." Mythbusters
Does that mean that I could hook up a large plece of metal to a pin, and have it detect my motion? Is this the basis of a PIR sensor?
Post Edited By Moderator (Chris Savage (Parallax)) : 8/5/2006 1:49:00 AM GMT
