Basic Stamp/Boe BOt to UVtron Flame Detector
Dear friends, who knows and give me examples to using UVtron Flame Detector using Boe BOt ? I can't find it . I want to make Boe BOt able to detecting fire.
THanks for your help.
Widodo
Inoneisa
Widodo
Inoneisa
- Stephen
With the driver board you can purchase from acroname, you can use the COUNT command to count the number of pulses (which is proportional to the amount of UV light) outputted from the sensor.
' {$STAMP BS2} ' Quick UVTron Demo 'constants UVtron_Pin CON 0 ' use P0 for UVtron How_long CON 1000 ' count amount of pulses for 1 second 'variables UVlight VAR Word main: GOSUB check_sensor DEBUG ? UVlight GOTO main check_sensor: COUNT UVtron_Pin,How_long,UVlight RETURNThis worked when I wired up a quick circuit.
The debug terminal output should be 0 until there is UV light present, then you will get a decimal number that changes with changes in UV light.
Also note the jumper wire on the right-hand side (facing rear of board).
There are pairs of pads numbered 3, 5, 7, 9, and a pair with no marking.
If you place the jumper (requires desoldering and re-soldering) across the pads that are closest to you (no marking), you should get more sensitivity.
Hope this helps.
Post Edited (johnsrobotics) : 6/10/2006 7:30:15 AM GMT
