ASM ref to Main memory OTHER than PAR passing address ?
This program is a outline of my program that works, but why can't I set AddressOfCtrAsmMainMem LONG @CtrAsmMainMem·in DAT area instead of using PAR ?
VAR
·· LONG CtrAsmMainMem··· 'used by SPIN program to display on VGA monitor
PUB VgaTextDemoStart | i
· cognew(@asm_entry, @CtrAsmMainMem) 'launch assembly program into a seperate COG , send memory pointer for CtrAsmMainMem·to the cog parameter
· repeat
··· text.str(string($A,1,$B,4,8)) 'set location
··· text.bin(CtrAsmMainMem,32) 'display counter in binary
DAT
··············· ··· org
·asm_entry···· mov ·AddressOfCtrAsmMainMem,PAR·· [url=mailto:'PAR=@CtrAsmMainMem]'PAR=@CtrAsmMainMem[/url] was sent via, cognew(@asm_entry, @CtrAsmMainMem) .
·loop·············add AsmCounterCog,#1
···· ············· wrlong··· AsmCounterCog,AddressOfCtrAsmMainMem 'hub instruction to send data to main memory for spin pgm access in another cog
·················· jmp··loop
AddressOfCtrAsmMainMem LONG @CtrAsmMainMem··'the·SPIN program has its variables in·MAIN memory,·compile ERROR="expected a DAT symbol"
AsmCounterCog··· res······ 1······························· 'the·ASM program has its variables in·COG memory
VAR
· repeat
DAT
· AddressOfCtrAsmMainMem := @CtrAsmMainMem
· cognew(@asm_entry, 0) 'launch assembly program into a seperate COG
· repeat
Life is one giant teacup ride.
before launching the cog
dat_long := @variable
in the DAT section
dat_long LONG 0
Who says you have to have knowledge to use it?
I've killed a fly with my bare mind.
Post Edited (CJ) : 6/8/2006 2:33:39 AM GMT
Error "expected an instruction or a variable"
If I use AddressOfCtrAsmMainMem long 0
no compile error and program works fine
and after comenting out the line to transfer via PAR, program works fine.
As far as I under stand the only difference is that the ** Long 0 is initalised and the ** RES is not initalised
and in either case "AddressOfCtrAsmMainMem" should be in the COG memory after the ASM program code.
Core docs, hub instructions p7, "WRLONG D,S 'Write D into long at S"
D points to the COG memory with the data to write
S points to the COG memory with the pointer to the main memory address that the data will be moved to.
So how can the spin program do AddressOfCtrAsmMainMem := @CtrAsmMainMem before the asm COG is launched in the next line ?
I thought that spin running in a COG can't store in to another COG if that is where "AddressOfCtrAsmMainMem" is located.
Revised program is atached.
I just saw the other post
just define your long(don't use RES) that will be loaded into the cog then at runtime before launching the cog, put in a line that goes something like this
This is becoming more confusing, just what is done by compiler and spin and when and where ?
At least the revised program works.
Phillip Y.
· AddressOfCtrAsmMainMem := @CtrAsmMainMem ' overwrites DAT AsmMainMem long 0 in MAIN memory
· cognew(@asm_entry, 0) 'launch assembly program into a seperate COG, this cog loads a copy of the MODIFIED AddressOfCtrAsmMainMem long 0.
DAT 'remember this DAT is in MAIN mem, it is copied to the new cog by "cognew(@asm_entry, 0)"
·AddressOfCtrAsmMainMem long 0· 'SPIN code "AddressOfCtrAsmMainMem := @CtrAsmMainMem" overwrites the 0 with @CtrAsmMainMem
Thus there are 2 places labled "AsmMainMem", the become seperate and independant,
1st, The SPIN code refers to the MAIN memory for AsmMainMem in the DAT area
2nd, The ASM· code refers to its COG· memory for AsmMainMem, that was copied from the DAT area with COGNEW.
Since all SPIN code uses main mem there is no problem exchanging PUB variables between SPIN programs,
BUT all ASM·cogs need to·use WRLONG and RDLONG to exchange data with each other or SPIN code via MAIN memory.
NOW this ASM code works ,·"WRLONG· AsmCounterLong,AddressOfCtrAsmMainMem 'hub instruction to send data to main memory for spin pgm to display".
Phillip Y.
