Power supply from a 220v line
Hey
I want to make a power supply for mys basic stamp, but as the electrical line im gonna have is 220v·and·I·dont know what to do to have a safe power supply for my basic stamp.
Best Regards
Manuel C. Reinhard
Best Regards
Manuel C. Reinhard
A good one(stabilized/regulated, delivering 500mA or more) shouldn't cost too much, and certainly won't burn down the house.
Don't visit my new website...
Best Regards
Manuel C. Reinhard
The only trick to using an ATX power supply is that you have to short pin 14 on the ATX board connector to ground in order to "soft" turn-on the power-supply on. This is easily accomplished with a, wait for it, paper-clip because pin 14 is adjacent to a ground wire and a paper-clip or suitable _insulated_ jumper wire can be inserted into the connector housing which holds it snug against the pins. Once you have this short in place, the power-switch on the power-supply itself can be used to turn-on/off the PSU.
The best thing about about using this style of PSU is that the power leads are relatively long, easily extended, and easily connected to a breadboard using a pin-header and the floppy power connector (see photos).
I wouldn't connect that if I were you...
Post Edited (aalegado) : 6/11/2006 6:33:27 PM GMT
I'll post the schematics by the night!!!
-Rule your Destiny-
--Be Good. Be Bad. Be Provas--
- Rick
Ecxept from that it's fairly cheaper to make your own wall pack than buy it.... (a 1.5VA is just very fine to me at 12AC (you have to make it DC although...))
-Rule your Destiny-
Need more current? Buy the 12V@1A unit (#105478 and about $9 changing the total to $19).
I think an ATX PSU is still a bargain compared to this because you get the 110/220 capability built-in plus the current capacity to toast 10W resistors to your heart's content and still power your 5V circuits with nary a hiccup.
