timing
As a final engineering project, we are making a track that will time and calculate the velocity of mousetrap race cars. The track has a series of lasers hitting photoresistors, which are tied into a BOE board. Every time a laser is blocked by a car, we should be able to measure a voltage change (and we can). Since the velocity measurements will be feet/second, we need a way to accurately measure the time between voltage changes in seconds (or some other fairly absolute measure of time). Since we have to mark the time exactly when the voltage changes, pause and count do not seem to be viable alternatives. Does anyone have an alternate way of measuring the time between two events in absolute terms using the BOE? (Oh, and using count and dividing the total time by the number of changes will not work, since we want the max velocity, not an average). Thanks in advance for any help.
On another note, my brother adjusts camera (35mm SLR's) and needed a device to measure shutter speed. Using a IR Transistor, a pointer laser, and an LCD I developed him a nice little device that can measure very accurately, though it does 'miss' now and then due to the timeout and looping involved.
Good luck!
Martin Hebel
Southern Illinois University Carbondale - Electronic Systems Technologies
Personal Links with plenty of BASIC Stamp info
StampPlot - Graphical Data Acquisition and Control
-MH
Martin Hebel
-Martin
Martin Hebel
