Parallax Standard Servo
I am having some difficulty wrapping my mind around the idea of servo control. I got a servo with the discovery kit. So I want to control to motor so it rotates continously (360 degrees). I am new to this stuff, so can someone explain to me how to make the motor rotate continuously. Also I want to know how reverse direction.
Thank you All
Thank you All
The easiest way to change from holding a position in a 180 degree range to rotating backwards and forwards in a 360 degree range is to get the Parallax Continuous Rotation Servo. They're only $6.95, and they take the same kind of signals a standard servo takes.
For all kinds of continuous rotation servo control examples, you can download the PDF version of the Robotics with the Boe-Bot text from the Boe-Bot Robot Kit web page.· The best place to start with continuous rotation servo control is Chapter 2, Activity #3, #4, and #6.
One final note, it is not difficult to modify a standard servo to be a continuous rotation servo.· Use these words in Google: Modifying Hobby Servo Motors for Continuous Rotation.· However, I don't recommend it.· A standard servo is nice to have around for a variety of projects, and the price of the continuous rotation servos is much less than any standard hobby servo.· The Parallax Standard Servo is the least expensive·hobby servo·I know of, and it's $12.· You can get two continuous rotation servos for about the same price.
Post Edited (Andy Lindsay (Parallax)) : 6/7/2006 1:01:55 AM GMT
