Thanks steven. The homework board has all three on it and in an example of a simple servo setup one lead of the servo was connected there. Is there any discussion in any PDF that will explain this better?
You see, "Vin" is designed to take a 9-volt battery, or a 6-volt battery pack (or 4 1.5 volt alkalines, same thing). Or, a 12-volt 'wall-wart' unregulated DC supply.
"Vin" is then fed to a "linear regulator", which drops its output voltage (Vdd) to +5 volts.
Now, if you're using battery power (that 6-volt pack above), and you're using Servo's, it's nice to be able to drive the servo supply with that 6 volts. So, Parallax put a jumper on the BOE that allows you to power the servo's from either Vdd (+5 volts) or Vin (6 volts). If you're Vin is above 6 volts, then you can't use it for the Servo's.
- Stephen
