Sensors Gas such as LP or Propane if anyone knows a source for such sensors, Th
maximus
Does anyone know a source for Gas sensors to interface with Microcontroller?
I need to measure Gas flow out of a Gas Tank LP, Or Propane
Thanks.
Thanks.
www.figarosensor.com
·for LP Gas. Again I forgot to Say FLOW Gas sensor I do Appreciate help in that subject.
http://us.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=230260&Row=129321&Site=US
It pulses at a rate depending the flow rate, so you can read that....but there's also an analog output from 0v to 10v scale, which you can read with a ADC chip.
I am having some luck with some european manufac, I will post any solution to the forum
