parallel lcd question
Hey, now that i made my now parallel lcd work and i have never worked with one before, i would like to ask:
Must I use the·Data command to store what I want to display on the lcd or is there another method, like if I want to display a variable that changes every second?
Best Regards
Manuel C. Reinhard
Best Regards
Manuel C. Reinhard
Best Regards
Manuel C. Reinhard
i think it turns out that you use the data command to load info into the eeprom because the stamp 2(for instance) only has 16 bytes of variable ram.allso, be carefull - dont give the screen more than 5volts. i found out the hard way that LCDs are absurdly efficient and can be powered off a BS2 pin, even!
i kept asking why a little routine couldnt load strings in and out just as easily, and couldnt get a usefull response. i also asked if there was code to make it easy to do these things...
i have an application where a user should be able to use a 11-key matrix to enter a number... i want each number to appear as it is typed... no idea how to do this yet.
it may mean putting a bunch of strings into the eeprom, then using their memory location to call them out.. so a subroutine would be supplied with an eeprom location and a string length, and do the rest... i will probably have this code working in the next day or so, and can share it...
good luck,
robert
Best Regards
Manuel C. Reinhard
Best Regards
Manuel C. Reinhard
try wbay for a parallel to serial IC.. i have seen them for $4.50 plus $3/shipping.
If want a piggyback board to plug the Phanderson controller chip go here www.wulfden.org/k107/
Best Regards
Manuel C. Reinhard
