Free 74HC14 Invert Schmitt Trigger...
I managed to order the wrong part from Digikey...
In stead of a 14 DIP I got the 14 SOIC...
Maybe I should have had another cup of coffe before hitting the submit button...![tongue.gif](http://forums.parallax.com/images/smilies/tongue.gif)
So if you think you can use 4 CD74HC14M (Digikey part 296-9179-5-nd) send me a PM with your name and address and I'll put these in the mail tomorrow...
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
Experience level:
/Bamse
UgH! they are sooo tiny.. joke sized... at least all 80 were only like $4.00 total... being Surface mount... i am deathly afraid of these...
gotta be more carefull with that digikey..
3D & 2D Design - Technical Documentation
www.robertguyser.com
Now if you want to solder the 74HC14 you 'll need s costum PCB or if you are good in soldering you can use the dead bug method... solder it with wires upside down...
Hope I made you understand...
Provas, Greece
-Rule your Destiny-
--Be Good. Be Bad. Be Provas--
I'll ordfer the real stuff (DIP) later in the project...
Experience level:
/Bamse
Ryan
Ryan Clarke
RClarke@Parallax.com
stand back! I have a slide rule and I know how to use it!
Got to sharpen it up and try again later this weekend...
Experience level:
/Bamse
I think it's probably easiest to just order some 74HC14 DIP from http://www.glitchbuster.com/...
He charges $0.25 per IC and shipping is only $1.95...
Experience level:
/Bamse
Those "Schmartboards" sound like a great idea for clumsy people like me.
But why are they so expensive ($10 for one protoboard)?
