Switching power to audio amplifiers
Short version: What's a good way to control power to audio amplifiers? I looked at the RC-4 and Crydom D2W203F, but I don't think the 2 amp capacity is enough. One of the amplifiers has a 3A fuse and the other has a 5A fuse.
Long version:
I have two audio amplifiers and an active crossover that I'd like to be able to switch on and off with a BS2 or SX. One audio amp is a 70-Watt tube amp and the other is a 200-Watt transistor amp (I'm in the US, so they're 110V). The crossover is a modified car audio crossover that I'm running off a 12V lead-acid battery. Currently I have a DPDT switch that switches the battery between either the preamp or a trickle charger. I control power to the amps by turning on and off a power strip.
There are two problems I want to solve. One is that if the preamp is turned on or off while the power amps are on (or the tube amp is off but not cooled down yet), there's a huge spike which could damage the speakers. I want to control the sequence and timing of power on/off to the components to eliminate the possibility of the spike. The other is that I want to be able to be able to turn the rig on and off with my remote. (I already bought an IR Buddy, so receiving and processing the IR from the remote shouldn't be an issue.)
I'm planning on controlling the power between the battery, charger, and crossover with a pair of MOSFETs, probably the IRF510s I have on hand (unless there's a reason I should use something else).
OS-X: because making Unix user-friendly was easier than debugging Windows
Long version:
-dave
This is not a sig. This is a duck. Quack.
I ordered some 5A solid-state relays <LINK>. Can I connect them directly to the SX output pin?
What's the best way to connect 14-gauge wire to the AC side of the relays?
·· Yes you can, but you should check the current draw, then, depending on how many you are connecting you may want to be careful about drawing too much current from too many I/O pins at once.· See the SX Datasheet for current handling information.
csavage@parallax.com
·· By the way, I have built many Custom Amplifiers over the years (used to be a big part of my business) and I have always used mechanical Relays in my systems.· In fact, the amplifier running on this computer works the same way.· You press a button (Which is read by the Stamp) and it turns on a Relay through a 2N2222 transistor.· Tried and true.· There are actually 4 relays in this amplifier.· The Tape Monitor circuit is identical except the relays are smaller and there are two of them.· The muting circuit uses a small PCB Relay like the Tape Monitor Circuit uses.· The Power Relay is the big one...10A contacts.··And your friend was right...Inrush current should always be taken into consideration when switching a load such as this.
