Triac
I am trying to control a positive or negative DC voltage with an SX pin. I am planning on using a triac to accomplish this. The load on the triac is a 12 volt DC motor that draws up to 3 amps (I think). What is the best way to drive a triac for this purpose, or is a triac the best way?
Well well, I'm seeing things, three of them.
-Stanley Blystone
-Stanley Blystone
Post Edited (PJ Allen) : 6/5/2006 12:07:23 AM GMT
-Stanley Blystone
Second - Properly sized (see above) H-Bridge - Home-built with discrete components or a assembled unit such as SN754410.
For what I suspect you're trying to do, Nate is right on the money. Here is an H-Bridge project which should meet your voltage and current needs. It's complete with images for making the traces on a PCB as well, for a nice professional job:
http://www.bobblick.com/techref/projects/hbridge/hbridge.html
If you'd prefer a canned solution, but don't mind constructing a small kit, this should meet your needs as well:
http://www.hobbyengineering.com/H1918.html
Bruce Bates
<!--StartFragment -->
if you want a varialbe control, i think it makes everything far more confusing, otherwise a tip120\tip125 h-bridge would probably work... for the 1-direction circuit you can use a half h-bridge... if your application was more intensive than a fan, you would be well advised to try a h-bridge chip, but i think a simple fan controller can be built easily enough with some transistors.
a triac or SCR would be helpfull if you were dealing with AC, i believe...
Best Regards
Manuel C. Reinhard
