CNC Machine Trouble
Hello,
·· I am having trouble testing my CNC machine. Is there any programs (in Bs2·PBASIC)·for testing the CNC machine?
Any replies to this post would be greatly appreciated!
- Stephen
if u need more info please ask
Seriously, every machine is going to be different. We need to know what type of signals it needs.
Do you have a manual ? Can you post a link to it ?
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"The meaning of life, is to give life meaning" Unknown.
Post Edited (Bean (Hitt Consulting)) : 7/27/2006 11:24:44 PM GMT
Post Edited ($TAMP&ME) : 7/28/2006 1:10:07 AM GMT
- Stephen
Can you post a schematic ?
Bean.
What's the problem you're having with the CNC?
You say it's homemade....have you in herited from someone else? Had it worked at one point?!
Give us the symptom man!! [noparse];)[/noparse]
Since it's connected to a stamp, do you have the code "some person" used to program that stamp? If not and you're thinking you can grab the code off the stamp...sorry, can't do that!
The more information you provide us, the better we can help you!
Telling a mechanic the car doesn't work because the "check engine" light is on, will only put you in a position to get taken advantage of! [noparse];)[/noparse]
Steve
1.·I dont have the code for BS2PX
2. the·4001 (logical or gate) is transmitting but not from the stamp instead from the 4 10uf capacitors that i put for power brekage (ex. OR --/\/\/\
< stepper
····················································· 1K···· |··················································
······························································· <--->CAP - (negative side connected to step coils)
·(5V/1000 = X 1000)·= 5mA flowing into OR gate
BS2 is here for the world
and
the world is here for the BS2
I assume you are using uni-polar steppers (5 or 6 wires) ?
Your ascii drawing didn't come out right.
Did you built this ? Or did someone else ?
Bean.
the only modification i did was instead of using a PIC and a SX24
and
Bean.
