Parallax Servo Controller (PSCusb): Can you use USB version with a Stamp?
Can you use the Parallax Servo Controller (PSCusb) with a Stamp?· I would like to be able to use the Servo Controller either from the PC (via USB) or the Stamp (via TTL Serial).··
Is the same serial interface available on the USB version as the Serial version of the PSC?·
Also is the STAMP program available to replay PSCI sequences (referenced in the PSCusb manual)?
Thanks !
·- Tom
Thanks !
·- Tom
·· Yes, you can use the USB PSC the same as the Serial version when using a BASIC Stamp.· The only difference between the two is the added USB connection on the USB Version.· As for the playback software it's something we're still working on but currently not available.· Take care.
csavage@parallax.com
Is this a desktop computer, or a laptop? Did you install the USB drivers? Are you going direct-to-USB on the computer, or using a serial-to-USB converter? If the latter, which brand are you using?
Bruce Bates
<!--StartFragment -->
