Basic Stamp BS2p and Agilent Waveform Generator
I am trying to get my basic stamp to communicate with an Agilent 33250A Arbitrary Waveform Generator via RS-232...I am not trying to do anything specific with the generator, I just want to figure out how to do serial communication. The command set the generator offers seems to be very similar to other devices, however I have not been able to figure out how to do serial communication on anything yet. Here is a subroutine I am trying to make work now:
Currently, the device reports input buffer overrun and packet framing errors, or otherwise fails to effect any outcome whatsoever. The function generator is connected to the BS2P24/40 via RS-232 crossover.
Thanks for the help.
ResetValueInt CON 2 ResetValueDec CON 5 COMOutput CON 16 COMInput CON 16 COMBaud CON 110 FUNC_GEN_XON CON $11 FUNC_GEN_XOFF CON $13 ResetVoltage: SEROUT COMOutput, COMBaud, [noparse][[/noparse]HEX FUNC_GEN_XON] PAUSE 50 SEROUT COMOutput, COMBaud, [noparse][[/noparse]"output:state off", CR] PAUSE 50 SEROUT COMOutput, COMBaud, [noparse][[/noparse]"output:sync off", CR] PAUSE 50 SEROUT COMOutput, COMBaud, [noparse][[/noparse]"func square", CR] PAUSE 50 SEROUT COMOutput, COMBaud, [noparse][[/noparse]"frequency 1", CR] PAUSE 50 SEROUT COMOutput, COMBaud, [noparse][[/noparse]"volt:high 1", CR] PAUSE 50 SEROUT COMOutput, COMBaud, [noparse][[/noparse]"volt:offset 0", CR] ' SEROUT COMOutput, COMBaud, [noparse][[/noparse]"func:square:", CR] PAUSE 50 SEROUT COMOutput, COMBaud, [noparse][[/noparse]"burst:ncycles 1", CR] PAUSE 50 SEROUT COMOutput, COMBaud, [noparse][[/noparse]"output:state on", CR] PAUSE 50 SEROUT COMOutput, COMBaud, [noparse][[/noparse]"output:sync on", CR] PAUSE 50 SEROUT COMOutput, COMBaud, [noparse][[/noparse]HEX FUNC_GEN_XOFF] RETURN
That can cause framing errors too.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
COMING SOON "SD DATA LOGGER" www.sddatalogger.com
"I reject your reality, and substitute my own." Mythbusters
It would appear from the Agilent documentation that the default baud rate is 57.6 KBPS, unless you have changed it. Presuming you have, I suspct you now need to implement flow control for this to work properly. Your program is presently specifying a baud rate of 19.2 KBPS.
Just as a matter of reference, the default parameters for this generator are:
57.6 KBPS, 8, N, 1 start, 1 stop, DTR/DSR enabled
Since the units are not synched without the flow control, I suspect that's where these framing errors and/or data over-runs are coming from.
Just as a matter of information, with flow control enabled, the BS-2p is speed-limited to 19.2 KBPS. The PBASIC Manual or the PBASIC Help File will show you what you need to do to enable flow control.
Bruce Bates
<!--StartFragment -->
I dont think I a m familiar with your notation. The user manual for this device shows that it can do even or odd parity, as:
Start | 7 bits | Parity bit | stop bit
Or with no parity as:
Start | 8 bits | stop bit
I do not know what to do with the start and stop bits at this time, but if I am trying to send ascii, then that is 8 bits per char, does this mean that I have to do something smart with the bits before and after? Or is there some way I can tell the stamp to do it right?
Bean:
I don't think I know what those are...
As I mentioned a few moments ago, the PBASIC Manual or the PBASIC Help File will show you what you need to do to enable flow control. There is a standard RS-232 connector on the back of the generator, so everything should fall into place once you read the instructions, as the wiring set-up for flow control is also indicated in those instructions.
Bruce Bates
