problem converting pBasic to Javelin; ADC0838
Hi Javeliners;
I am having a problem getting my ADC0838 class to work. It is based on code that is working in a pBasic program (excerpts shown below)
in main..
CS1···· PIN· 5····· ' ADC0838.18 chip select (common data i/0, clk )
DATI PIN 6········· ' ADC0838.17 data in·· (must have sep data line for a/d to work)
DATO PIN 6········· ' ADC0838.14 data out········· "··· "
Clock2· CON· 0····· ' Orange shift clock (74x165.2),(ADC0838.16)·
·IF( FADC ) THEN GOSUB Adc_0838
Adc_0838:
··· 'DEBUG CRSRXY, 0, 1, "Program FADC·· ", CR
··· 'Channel = 0
··· HIGH CS1··········· ' from other working prog··· .. triggers on high to low
··· LOW CS1············ ' ""
··· 'MUXBYTE = %11000 | ((Channel & %001) << 2) | ((Channel & %110) >> 1)
··· MUXBYTE = %11000 | ((0 & %001) << 2) | ((0 & %110) >> 1)
··· SHIFTOUT DATI,Clock2,MSBFIRST,[noparse][[/noparse]MUXBYTE\5]
··· SHIFTIN DATO,Clock2,MSBPOST,[noparse][[/noparse]ADCRes]
··· 'DEBUG CRSRXY, 0, 9, "ADCRes = ", DEC3 ADCRes
··· ADCWord = (ADCRes*100)*/5
··· pot =· ADCWord/5········ ' convert ADC chn0 val to range 0->99 for output
··· 'Channel = 1
··· MUXBYTE = %11000 | ((1 & %001) << 2) | ((1 & %110) >> 1)
··· lgt =· ADCWord/5····· ' convert ADC chn1 val to range 0->99 for output
··· DEBUG CRSRXY, 0, 9,"
",CR
··· DEBUG CRSRXY, 0, 10," Channel ;··· MUXBYTE·· ;···· ADCResult··· ;··· Voltage*100"· ,CR
··· DEBUG CRSRXY, 0, 11,"
",CR
··· DEBUG CRSRXY, 0, 12, DEC 1," (%",BIN3 1,") ;· ",DEC MUXBYTE, " (%",BIN MUXBYTE,") ;· "
··· 'DEBUG CRSRXY, 0, 12, DEC CHANNEL," (%",BIN3 Channel,") ;· ",DEC MUXBYTE, " (%",BIN MUXBYTE,") ;· "
··· DEBUG CRSRXY, 0, 13, DEC3 ADCRes," (%",BIN8 ADCRes,") ;· ",DEC3 lgt," (%",BIN8 lgt,") " , CR
··· 'DEBUG CRSRXY, 0, 4, "pot = ", DEC pot, CR
··· 'DEBUG CRSRXY, 0, 5, "lgt = ", DEC lgt, CR
· RETURN
this gives debug feedback like (when using BS2pe)
· channel··· muxbyte········ adcResult·········· volt*100
1 (%001), 28 (%11100), 154 (%10011000), 060 (%00111011)
now my new javelin program Multi5.java (attached) shows adcResult = 255... for same condition. Also attached is the ADC0838.java. I have tried to understand and set the parameters the same... and I am using the same ciruit and pin numbers but swapped in Javelin Stamp.
Can anyone spot the problem?
Thanks, John
in main..
Adc_0838:
··· 'Channel = 0
··· 'Channel = 1
",CR
",CR
· RETURN
Thanks, John
Put
System.out.print("clockIn=");
System.out.println(clockIn);
after the shiftIn() in your read() method of the· adc0838 class.
regards peter
http://forums.parallax.com/showthread.php?p=519918
regards peter
muxbyte=24 clockIn=511
muxbyte=28 clockIn=511
lgt=-1 pot=-1
in my pBasic program the equivalent result for clockIn was ADCresult = 154
you might have noticed some shifts I did on muxbyte << 11
and clockIn >> 8 (the output above was before I did the shift)
..these appear to be required since javelin is using 16 bit words and pBasic uses 8 bit words
john
which cannot be with 8bit data) that must be stripped off.
I think the right code is
··· CPU.writePin(enablePin,false);· //enable, triggers at falling edge
··· CPU.shiftOut(dataPin, clockPin, nBits, CPU.SHIFT_MSB, muxbyte <<11);
··· clockIn = CPU.shiftIn(dataPin,clockPin,readSize,CPU.POST_CLOCK_MSB);
··· clockIn = clockIn&0xFF; //strip off extra bit
··· CPU.writePin(enablePin,true);··· // disable, setup for next trigger
regards peter
I've double checked the pins
There is the CPU.writePin(clockPin, false); // to give positive pulses
There is the hgh to low trigger
To my mind it is likely one of the following is wrong orr behaving different to pBasic:
on CPU.shiftOut(dataPin, clockPin, nBits, CPU.SHIFT_MSB, muxbyte <<11);
CPU.SHIFT_MSB // MSB sent first, nBits=5
muxbyte << 11 // I want top 5 bits shifted out, so I shift them to the top first
on CPU.shiftIn(dataPin,clockPin,readSize,CPU.POST_CLOCK_MSB);
CPU.POST_CLOCK_MSB // post clock sampling and MSB-first transmission
john
····· lgt = lgt*100/255-1;·· // -1 added to avoid field overflow at 255
····· pot = adc.read(1);···· // read pot from chn 1
····· pot = pot*100/255-1;
to
····· lgt = (lgt*100)/255;
····· pot = (pot*100)/255;
I think the IDE is smart enough to recognize that mathematically
····· lgt = lgt*100/255-1 equals lgt=lgt*constant-1
where constant is·100/255
But due to integer math, 100/255 = 0, hence lgt=-1 using the current formula.
It is always wise to use brackets in your formula. That way you have full control
on how calculation is done.
regards peter
··· CPU.delay(100);
··· lastRaw = clockIn;······························ // raw is protected
(there is no 9th bit there)
so I guess the shift modes are correct.
regards peter
Then in read method, make CS low, then read data, then make CS high again.
That is the order used in the BS2 program from that other thread.
Read_0838:
· LOW CS
· ' setup mux bits for single-ended mode
· LOOKUP chan, [noparse][[/noparse]%1000, %1100, %1001, %1101,
··············· %1010, %1110, %1011, %1111], mux
· SHIFTOUT Dio, CLk, MSBFIRST, [noparse][[/noparse]1\1, mux\4]···· ' send start, mux
· SHIFTIN Dio, Clk, MSBPOST, [noparse][[/noparse]adc(chan)\9]····· ' read selected input into byte·variable
· HIGH CS
· RETURN
regards peter
I have incorporated all your suggestions and get clockIn=255 ..want values in range approx: 30->230·.. so it still is not working as far as I can tell.
debug shows:
muxbyte=24 dataPin=6 clockPin=0 enablePin=5 readSize=9 clockIn=255
latest programs attached
I plugged by BS2pe back in and it still works..
john
