DIY Motorcontroller
anyone know of a good one i can build myself, relativly cheap that has FWD and RVS? i have (2x) 12v(max) 20A(max) car window motors i want to use on my robot. i want to build it myself simply because of the fact that its cheaper. i looked at the HB-25, but i cant justify the cost for a hobby. i searched google a little, but didnt find anything too great.
1+1=10
This pdf is helpful downloads.solarbotics.com/PDF/kit10.pdf
This looks like exactly what i want to do
www.bobblick.com/techref/projects/sv2pwm/sv2pwm.html
Post Edited (Cheeto) : 6/3/2006 12:50:52 AM GMT
S0, the real question is whether you want a durible designed product or something that may be relatively short-lived.· Just having a schematic on paper is not enough in this case.· All the power output side components need to be rated at 20 amps or greater AND it certainly wouldn't hurt to have some fuses and thermal shut down.· You may also have transient peaks far beyond the 20 amps if there is a jam up.
The L293 won't work, just smoke.· Have you considered trying some double pole, double throw relays?· They are a bit noisy and slow, but for DIY it is the easiest.
"You have to have a dream so you can get up in the morning." - Billy Wilder 1906-?
·······································································Tropical regards,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
Post Edited (Kramer) : 6/11/2006 10:36:19 AM GMT
You might be pushing the limits of the wire you are using, not to mention the heat problems associated with such a light wire/heavy load.
I would use at least a 14 guage finely stranded copper wire....
Bob N9LVU
