Basic Stamp SEROUT Help
Hi, I am new with basic stamp and I was wondering if someone could answer two questions for me -
1) I want to output the sequence·137 0 255 128 0 (5 seperate numbers) to a Roomba which recognizes them individually.· However, the only·way that works for me is·-
SEROUT Tpin, BMode_TX, [noparse][[/noparse]137]
SEROUT Tpin, BMode_TX, [noparse][[/noparse]0]
SEROUT Tpin, BMode_TX, [noparse][[/noparse]255]
SEROUT Tpin, BMode_TX, [noparse][[/noparse]128]
Is there a more concise way of writing this? (assuming I am communicating at correct Tpin and BMode_TX inititalized already)
2) I also want to be able to write a program that takes an inputted key to make a decision.· Instead of using numbers to denote my selection, I would like to use characters.
If my code is this - SERIN RPin, BMode_RX, MaxTime, Timeout, [noparse][[/noparse]Choice]· and choice holds the character selection, what type should I declare "choice" as?
Thank you for your time and efforts!· It is much appreciated.
·· You could try it this way:
If that is not working, but the other way is, then it would seem the data is going to fast for the receiving device.· If that's the case then you could use a pacing value to slow it down a bit.
csavage@parallax.com
I would like to be able to implement the following code -
Choice VAR Word
DEBUG CLS,"Which direction would you like to go?",CR
DEBUG "[noparse][[/noparse]F]orward, [noparse][[/noparse]B]ack, [noparse][[/noparse]L]eft, [noparse][[/noparse]R]ight, [noparse][[/noparse]S]top",CR, ">> "· ' Request Choice
SERIN RPin, BMode_RX, MaxTime, Timeout, [noparse][[/noparse]Word Choice] ' Await serial data
But it won't accept a character (i.e. 'R') for "Choice".· What type of variable should I declare Choice to be and how should I change my code?
All the SERIN documentation seems to use DEC as the argument but I would like to use something besides numbers.
Thank you [noparse]:)[/noparse]
Just define it as a BYTE like this:
Choice VAR Byte
DEBUG "[noparse][[/noparse]F]orward, [noparse][[/noparse]B]ack, [noparse][[/noparse]L]eft, [noparse][[/noparse]R]ight, [noparse][[/noparse]S]top",CR,">>"
SERIN RPin, BMode_RX, MaxTime, Timeout, [noparse][[/noparse]Choice>]
Then set up a SELECT CASE Statement:
Select Choice
Case = "F" or "f"
Case = "B' or "b"
etc.
Bruce Bates
<!--StartFragment -->
Post Edited (Bruce Bates) : 6/1/2006 8:34:57 PM GMT
If anyone can remove the overstrikes from this last post, PLEASE do so! I have NO IDEA how they got in there.
I even tried changing the entire text letter-by-letter, but STILL couldn't remove them!
Web posting BYTES!
Bruce Bates
OS-X: because making Unix user-friendly was easier than debugging Windows
