I2C Pullups
If you use any pins other than 28 and 29 for an I2C device, external pullups are required.· Is that correct?
Sid
Sid Weaver
Do you have a Stamp Tester yet?
Sid
Sid Weaver
It doesn't matter which pins you use, pullups should always be required on the propeller, sx, and basic stamp to assure good communications.
Oliver
