rs232 volage into stamp pin...
Hi all,
I would like to hook the DTR from a serial printer straight to a stamp input.
Would something like a 10K resistor be OK to protect the stamp input ?
Cheers,
Chris
West Oz.
Cheers,
Chris
West Oz.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
COMING SOON "SD DATA LOGGER" www.sddatalogger.com
"I reject your reality, and substitute my own." Mythbusters
What happens is, the +- 12 volt signal can be 'clipped' internally with the PIC16C57 'protection diodes' on each pin. However, these 'protection diodes' can only handle so much current. So, the 22 Kohm resistor reduces the amount of current so the protection diode can 'clip' the signal without damage to the diodes.
The current is (using V = I*R) : (+12 - 5) / 22e3 == 0.318 mA
(-12 + 0.3) / 22e3 == 0.531 mA
You'd have to look at the data sheet on the PIC to see how much current the protection diodes can handle. Less than 1 mA shouldn't be a problem, though.
cheers, chris
