HELP!! ~ BOE revision B with servo controller revision B
Everyone, help me!! I have a difficulty on connecting servo controller to BOE. I read the manual that only show how to connect servo controller to revision C. Is there any different? I tried to connect it by following the instruction that in the maunal, but BOE can't find servo controller. What's the problem?? Please help!!
·· I would be happy to help you.· Can you tell me if you have a serial or USB BOE Rev B?
csavage@parallax.com
It is USE BOE Rev B.
·· The connections for a BOE Rev C are the same for the USB BOE Rev B.· All you need to do is connect the PSC to the servo header using the cable.· Be sure to observe the order of the colors on the cable and that the Vin/Vdd jumper is set to Vdd.· I hope this helps.
