Error on IDE 2.0.3
Hello,
Well I just receive a bunch of Javelin from Parallax, and now that I try to create a progam i got the following error:
[noparse][[/noparse]Error IDE-0052] Incompatible firmware revision ($f).
I'm unsing the IDE 2.0.3
And It's look like the version of the Javelin is $50
how can I solve this issue and (if possible) keep only one IDE for all javelin version.
thanks for any help,
Arno
Arno
Then power off and on the javelin again.
Then try to identify again.
That worked for me when this happens.
Are you using a serial port or a usb2serial cable?
regards peter
now it's ok
don't ask what I did.
like you said, on-off and here it go
thanks for the trick
