beacon and an accompanying sensor? — Parallax Forums
evergreenevergreen Posts: 43
edited 2006-06-02 21:05 in General Discussion
What are my options when it comes to beacons and their accompanying sensors?
Pretty much, I would like to create a robot that follows a beacon, preferably one that is non audible and invisible. At most, the beacon would be 10' from its sensor.
  • Bruce BatesBruce Bates Posts: 3,045
    edited 2006-05-31 06:06
    evergreen -
    By your stated restrictions, you have all but pre-defined the beacon methodology to be either infrared ("invisible" light) or ultrasonic (sound outside the human range of hearing). Of the two, infrared will probably be the least expensive to impliment. RF is also possible, but difficult to implement if directionality is important.
    I would suggest a reasonably narrow, modulated infrared (I/R) beam, with a modulation frequency higher than 36-38 KHz. Infrared transmitters and receivers in the 40 KHz range should be relatively easy to find. This way you stay away from television and entertainment I/R remote controls which usually operate at those lower frequencies.
    Bruce Bates
    <!--StartFragment -->
  • A.C. fishingA.C. fishing Posts: 262
    edited 2006-06-02 20:53
    What aobut using some RFID readers? The only problem using Parallax's would be the beacon would have to be 4 inches away. Maybe you can find some long-range ones though.
    Somebody said...
    -Never Underestimate the power of human stupidity.
    A.C. fishing said...
    That requires active receivers, which are not as widely used and quite hard to find easy hobbist platforms for, additionally I dont think·they provide positional information, only identification information.
    1+1=10
