(Desperately in need of help) basic stamp2 code for servo, lcd, and keypad
I have the code for bs2 to control a servo, lcd, and keypad but cannot get it to work properly. my goal is to use the keypad to input the direction and speed of the motor. it is then suppose to move to desired value and display those values on the lcd. however, i can't get it to work. can anyone help me. ![shakehead.gif](http://forums.parallax.com/images/smilies/shakehead.gif)
sky
sky
OS-X: because making Unix user-friendly was easier than debugging Windows
'{$PBASIC 2.5}
'Variable Declaration
motor· VAR Byte 'this will equal a number 1-3 which correspond to the selected motor
number VAR Byte
'Servo Variable
temp··· VAR Word
cspeed· VAR Word
'Stepper Variable
t1······· VAR Word
ddt······ VAR Byte
direction CON 1
stspd···· VAR Byte
'DC Motor Variable
Cycles VAR Word···· 'Variable to store counted cycles.
paws·· VAR Word
speed· VAR Word
avespd VAR Word
'avespd = 0
speed = 0
paws = 1000
'LCD Variables
N9600·· CON $4054
I······ CON 254
CLR···· CON 1
db····· VAR Bit ' Debounce bit for use by keyScan.
press·· VAR Bit ' Flag to indicate keypress.
key···· VAR Nib ' Key number 0-15.
row···· VAR Nib ' Counter used in scanning keys.
cols··· VAR INB ' Input states of pins P4-P7.
LINE2·· CON 192
Scr_L·· CON 24
TEN···· VAR Byte
char··· VAR Byte
pound·· VAR Byte
poundt· VAR Byte
L1_C0·· CON 128
L1_C1·· CON 129
L1_C2·· CON 130
L1_C3·· CON 131
L1_C4·· CON 132
L1_C5·· CON 133
L1_C6·· CON 134
L1_C7·· CON 135
L1_C8·· CON 136
L1_C9·· CON 137
L1_C10· CON 138
L1_C11· CON 139
L1_C12· CON 140
L1_C13· CON 141
L1_C14· CON 142
L1_C15· CON 143
L2_C0·· CON 192
L2_C1·· CON 193
L2_C2·· CON 194
L2_C3·· CON 195
L2_C4·· CON 196
L2_C5·· CON 197
L2_C6·· CON 198
L2_C7·· CON 199
L2_C8·· CON 200
L2_C9·· CON 201
L2_C10· CON 202
L2_C11· CON 203
L2_C12· CON 204
L2_C13· CON 205
L2_C14· CON 206
L2_C15· CON 207
'This is the main routine for the program
'User Interface aspect, allows user to select the desired motor
Start:
PAUSE 104*4
SEROUT 12,N9600,[noparse][[/noparse]I,CLR]
PAUSE 1
SEROUT 12,N9600,[noparse][[/noparse]"MOTOR CONTROL"]
PAUSE 1
SEROUT 12,N9600,[noparse][[/noparse]I, L2_C0]
PAUSE 104
SEROUT 12,N9600,[noparse][[/noparse]"OPTIONS ARE:"]
PAUSE 3000
DEBUG TEN
'Informs the user to select servo Clockwise by entering 1
·SEROUT 12,N9600,[noparse][[/noparse]I,CLR]
·PAUSE 1
·SEROUT 12,N9600,[noparse][[/noparse]"Clockwise = 1"]
·PAUSE 2000
·DEBUG TEN
·'Informs the user to select the Servo Counter-Clockwise by entering 2
·PAUSE 1
·SEROUT 12,N9600,[noparse][[/noparse]"Counter C-W = 2"]
·PAUSE 2000
·DEBUG TEN
'Informs the user TO SELECT conintuous operation by entering 3
PAUSE 1
SEROUT 12,n9600,[noparse][[/noparse]"Continuous = 3"]
PAUSE 2000
DEBUG TEN
·CHOICE:
·'Prompts user for desired choice
·PAUSE 1
·SEROUT 12,N9600,[noparse][[/noparse]"Enter Choice:"]
·PAUSE 1500
·PAUSE 1
·DEBUG TEN
'run keypad scan
again:
GOSUB keyScan
IF press = 0 THEN Error
DEBUG "key pressed = ", HEX key,CR
IF (NOT key = 1 AND NOT key = 2 AND NOT key = 3) THEN Error
IF (key = 1) THEN GOTO Clockwise······· 'go to the servo motor routine
IF (key = 2) THEN GOTO CounterClockwise··· 'go to the stepper motor routine
IF (key = 3) THEN GOTO Continuous····· 'go to the DC motor routine
PAUSE 104
PAUSE 1
SEROUT 12,N9600,[noparse][[/noparse]char]
press = 0
GOTO again
'error display subroutine
Error:
PAUSE 104
PAUSE 1
SEROUT 12,N9600,[noparse][[/noparse]"····· Enter:"]
PAUSE 1
PAUSE 1
SEROUT 12,N9600,[noparse][[/noparse]"·· 1, 2, or· 3"]
PAUSE 1500
GOTO CHOICE
'Subroutine that allows user to enter double digit numbers
'Digits:····················· 'Convert number to decimal and save
'number = number * 10 + key·· ' - add key to number
'inDigits = inDigits + 1····· ' - update digit count
'hasNum = Yes················ ' - mark entry
'LOOP = LOOP +1
'return
· INPUT row······ ' Disconnect output on row.
RETURN·········· ' Return to program.
' clockwise servo subroutine
CounterClockwise:············· 'CounterClockwise Servo routine
·· test:
·· stspd=50
··· FOR temp= 250 TO 1250
··· PULSOUT 14,temp
··· temp=temp+stspd····· 'cspeed=75 or the value entered by the user
··· DEBUG? temp
··· PAUSE 50
··· NEXT
··· GOTO start
'we will use this as the code to control the servo motor. we will
'allow the user to select the desired rotation i.e. clockwise & counter-clockwise
'C&R will createN GOTO error 'display error
Clockwise:············· 'Clockwise Servo routine
·· stspd=50
··· FOR temp= 1250 TO 250
··· PULSOUT 14,temp
··· temp=temp-stspd
··· DEBUG? temp
··· PAUSE 50
··· NEXT
··· GOTO Start
' Continuous operation of the servo motor until interrupted by the user
Continuous:
· SEROUT 12,N9600,[noparse][[/noparse]I,CLR]
· PAUSE 1
· SEROUT 12,N9600,[noparse][[/noparse]"Hold 5 to Exit"]
· stspd=50
··· PULSOUT 14,temp
··· DEBUG? temp
··· PAUSE 50
··· NEXT
··· GOSUB keyscan
··· DEBUG "key pressed = ", HEX key,CR
··· IF (key = 5) THEN GOTO Start
··· PULSOUT 14,temp
··· temp=temp-stspd
··· DEBUG? temp
··· PAUSE 50
··· NEXT
··· back:
··· GOSUB keyscan
·GOTO Continuous
The following statement, extracted from your program, has faulty logic, since it will ALWAYS be FALSE:
Regardless of the value of "key" one of those three conditions will always be TRUE, and thus the overall statement will cause a FALSE condition to result. Reverse the logic, and it will be fine, as shown below:
IF (key = 1 OR key = 2 OR key = 3) THEN Key_Okay
GOTO Error
Error: 'Entered key not equal 1 => 3
Key_Okay:
Let's correct that error, and let's see where it goes from there.
Bruce Bates
<!--StartFragment -->
Post Edited (Bruce Bates) : 5/31/2006 5:13:10 AM GMT
