Fahrenhiet sensor
I found this great (maybe) device at allelectronics and i want to use it with my sx48 project.· it outputs a varied voltage depending on the temp.· do i need to use an A/D or is there a way to do it with the chip itself?
http://www.allelectronics.com/spec/LM34DZ.pdf
It's Only A Stupid Question If You Have Not Googled It First!!
Save yourself alot of headaches and just use a digital temperature sensor.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
COMING SOON "SD DATA LOGGER" www.sddatalogger.com
"I reject your reality, and substitute my own." Mythbusters
http://www.parallax.com/detail.asp?product_id=604-00011
http://www.parallax.com/detail.asp?product_id=ADC0831
csavage@parallax.com
You certainly can use an analog to digital converter to read the LM34. And if you need an A/D for other things that might make alot of sense. You can also use an Op-Amp to amplify the LM34 to get really good precision over a narrow temperature range.
Bean.
