PDF's for making a Propeller Dev Board
All,
Attached is three PDF files (1-1 scale) which can be used to create a double sided PCB of dimensions 105mm x 65mm.· These PDF's are for the "press-n-peel" http://www.maplin.co.uk/Module.aspx?ModuleNo=13464&criteria=Etching%20Equipment&doy=29m5·type of film transfer to PCB board techniques.· The board has 3.3V and 5V supplies, and ground pins available to connect to solderless breadboards.
The Realword_v1.pdf shows a "as made view" showing the components as they look when its made.
The Component side is a print of the "front" of the PCB,· this has been mirrored to come out the right way up when printed on transfer paper.
The Solder side file is the solder "back" of the PCB.
This drawing is updated to take note of the reboot issues raised on the forums (the SDA/SCL for the EEPROM are pulled to 3.3VDD not RES).· Link is http://forums.parallax.com/showthread.php?p=586995
Enjoy,
James
(use at your own risk etc...)
Post Edited (Javalin) : 5/29/2006 7:39:36 PM GMT
Enjoy,
James
