IR Sensors with Basic Stamp
Hi, I'm quite new to using the basic stamp and I want to make a robot that has collision detection.· I am looking for a low cost sensor to interface with either the BS2pe stamp.·
I've come across a sensor called the Sharp GP2D12 IR Sensor.· However I was wondering if it could be used since it seems to be a analog output.
The examples I've seen so far is that ppl tend to use the GP2D05 sensor which is·$19.· Since I need three, that is almost $60!· The·GP2D12 sensor on the other hand is just $11.50 each.· Much cheaper.·
http://www.acroname.com/robotics/info/examples/examples.html
If the BS2pe indeed can only take digital input, does anyone have an suggestions on what I should do to lower my costs?
Thank you for your expertise!
csavage@parallax.com
Also, if I were to purchase that part, how do I know which one out of the following on digikey site it is?
1) ADC0831CCN-ND (IC ADC 8BIT SER 1/0 MULTI OPTION)
2) ADC0831CCWM-ND (IC ADC 8BIT SERIAL I/O 14-SOIC)
3) ADC0831CCWMX-ND (IC CONVERTER A/D 8BIT 20-SOIC)
I wish to use the input from three IR sensors to control three futaba servos that can be bought off of the parallax store. In that case, do I need an ADC0831 "per sensor"?
Thanks once again! [noparse]:)[/noparse]
Post Edited (jkdalex) : 5/29/2006 5:08:20 AM GMT
http://www.parallax.com/detail.asp?product_id=ADC0831
