Program Efficency
The following program generates pulses on the RB.0 pin. The circuit uses a mosfet transistor to amplify the pulses for electric motor control. For speed adjustment, it takes a value on the RA port and converts it into pulse widths. It supports ten speeds including a full off (zero). Is their a way to shorten it?
Thank you [noparse]:)[/noparse]
Well well, I'm seeing things, three of them.
-Stanley Blystone
DEVICE SX18, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ 4_000_000
tris_b = 0 'Set RB port to outputs
plp_a = 0 'Enable pullup resistors for RA port
lowdur var byte 'Stores the length of time the signal is low.
ctr var byte 'Incrementing variable for loops.
Main:
if ra = 15 then 'The default value is 15 hence the pullups are enabled.
rb.0 = 0 'Signal is completely low.
goto Main 'Infinate loop.
endif
if ra = 0 then 'Zero represents the same value as 15.
rb.0 = 0 'Signal is completly low.
endif
if ra = 10 then 'Ten represents motor running at full speed.
rb.0 = 1 'Signal is completely high.
endif
lowdur = 10 - ra 'Calculate the time the signal is low.
rb.0 = 1 'Enable RB.0 which is the PWM pin.
for ctr = 0 to ra 'Loop number of times pulse is high.
pauseus 100 'Wait 100 microseconds.
next ctr
rb.0 = 0 'Disable RB.0
for ctr = 0 to lowdur 'Loop number of times pulse is low.
next ctr
-Stanley Blystone
You can use lookup or lookdown, and also you can use branch..
Not too sure if lookup lookdown and branch would make your ASSEMBLY code faster (shorter) but you can try.
Also, if you want to speed up your program, you need to think about how you can make the program without using the PAUSE statement. PAUSEUS allows smaller pauses...
Also you can use COUNTING to do things that require a pause, instead of an actual pause statement.
Like for instance...
I can say
Or I can do this
Main: If nopause = 50 then HIGH led nopause = 0 Else LOW led nopause = nopause + 1 Endif GOTO MainThe second example actually allows the entire program to loop constantly with no pausing at all. Thus you can do other things that might require you to not be pausing. You would need to tweak the correct max count to get your desired timing, and this timing could be thrown off a bit if you have other statements that allow different routes through your program.. It really depends on how EXACT you need your timing to be.
Meh. Nothing here, move along.
Post Edited (BPM) : 5/29/2006 3:01:42 AM GMT
Thanks again [noparse]:)[/noparse]
-Stanley Blystone
In that case, use lookdown and lookup.
Use the sxb help and look into lookdown and lookup, But because you don't really have alot of if then statements, i am not sure which code would be faster.
With lookdown and lookup you will be doing most of your code in subroutines.
