which capacitors do I use?
Okay, I'm so confused as to which capacitors I need for this circuit.
#1
http://www.parallax.com/dl/docs/prod/boards/BS2CarrierBdSchem.pdf
Which 0.1 microfared capacitors should I get? There are so many types out there.
#2
For a simple R/C circuit on a barometric sensor (0-5v), which .01, 1, and .33 microfared capacitor should I get?
Thanks!
#1
#2
Thanks!
Regarding example #2: Don't know the application --·is tight tolerance required·or stability over temperature?· Either way, don't sweat the small-stuff. ·I think that, again, and not to be glib, that capacitance is capacitance.· Just get the values specified; run it up the flag-pole and see if anyone salutes.
Nothing will get wrecked or hobbled in any event.· As a caveat, I would suggest you get capacitors rated at least 15-20V, as obtainable.
csavage@parallax.com
I'm building that circuit so I don't need the board. Hopefully it work!
