Buried Wire Fence
All,
I have been reading the archives looking to see if any one has built a buried wired fence system or connected into a dog collar.·· I can’t figure how and this is my last step to finish a robot lawn mower.
Tim
Tim
To keep a robomower from leaving a yard with no fence you could try rigging up a center RF transmitter and reciever. The transmitter kicks out a certain amount of RF and can be adjusted for range. Once the robot detects when the RF is low (where it roughly passes the yard limit) it can turn and drive back to the signal. The setup may only work limitedly though as it tends to be a circular transmission radius. There are a few RF schematics out there if you google for it.
One other idea is to have a visible reflector that is (for example) about 3 inches high and made of white raincoat and wire to anchor it every few feet. A trip to Walmart and some glue should work well. Once the mini border is setup, the robomower could have IR sensors that detect reflection. I dont know how well IR sensors work in sunlight. So this might work on low sun conditions. Also I dont know if you would favor the look of the white border. Maybe a green border could work and still server as being detectable by either the IR sensors or some other detector.
Another idea which could work is a string setup. The string is held high enough and stretches from one edge of the yard to another edge. Tied to a plant or fence edge or something along those lines. The string can be used to trip a sensor atop the robot telling it to backup and change directions. The string can be setup whenever you need to cut the grass and removed when needed.
http://www.robotshop.se/micro/robocut_us.html
csavage@parallax.com
Thanks for the response.· I agree these guys have such a nice web site with so much information.· I have followed their information for some time now.· I wonder why they or someone else does not sell a kit like they do here.
·My robomow is similar in that it uses a stamp and is much the same size.· I want to use a buried wire sensor but cannot make one work.· Robocuts site does not talk about what size coil they are using.· Their wire transmitter is easy in they are using a common 555 to create the waveform.·
This really has me stumped.· Any other ideas?
Tim
Tim
1+1=10
