PINK receiving info from Linux or Windows
I'm finding the PINK well-designed to deliver information to the outside world, but I'm having some trouble getting information into my BS2 from other computers using the PINK. It's easy enough between two BS2's equipped with the PINK by using the UDP, but UDP is a low level protocol not normally made available at the script level to Linux or Windows users. (Unless I'm missing a technique here, which is always possible.)
Right now, I'm planning to write a PERL script so my Linux boxes can send information to the BS2 over the local net and the only way I see to do that is the html POST method -- which is normally used by people to enter information into forms and such.
Before I do this work, do you at Parallax have any scripts already written that let a Linux box send information to a PINK on the net?
in this thread:
http://forums.parallax.com/showthread.php?p=556951
These require the NET 2.0 runtimes. A link for that is also in that thread.
regards peter
Ryan
Ryan Clarke
RClarke@Parallax.com
As I mentioned, you can use html POST for that purpose as well, but again that is really intended to carry out the action of a human, not another computer.
