current monitor?
stbrnrd
could the stamp monitor 4-20mA, without the need of (asides form a resistor or capacitor) external components? if so how would the comand be structured ... i need the current loop monitored, if it is within range (4-20mA) then a pin would do (either h or l), but if it isn't...another pin to do another action.
make sense?
make sense?
csavage@parallax.com
if you so incline would you be able to help on this ordeal? as far as needed components is concerned ....i'll take the fifth.
but i would greatly appreciate the help
note that I used a 12v supply because I am putting 24 volts into it. You can use 5v if needed, see the tool.
http://melrosemagazineonline.com/currentmonitor.jpg
http://www.analog.com/Analog_Root/static/techSupport/designTools/inter
activeTools/ad628/ad628.html?diffamp=AD628%20+%2F-%2015V
IN+(pin1) is on the side feeding into the resistor, IN-(pin8) is the side of the resistor going into your load. The shunt resistor has a voltage drop when there is a load present, the op amp converts the voltage drop(difference) into a positive going voltage directly proportional to the voltage drop(set by gain of course, so it could be larger or smaller).
Any differential op amp will work OK, but this chip are designed specifically for the purpose. google current sensing IC for other ideas, but this works incredibly well.
giving it a shot in a couple of days when the "samples" get here .
