BS2p40 display problem
Hello
I have just invested in a BS2p40. I tested it with some diodes and buttons and everything worked as expected. Then I tried my new display, a Matrix Orbital LK204-25-WB-C74. I found an extremely simple instruction on hove to make it work with I2C communication. I wired it up accordingly and run the code. The startup display goes on nicely on power up but nothing else happens. Could someone help me out, please?
csavage@parallax.com
This works if J0 is IN, J1 is OUT, J2 is IN and J3 is OUT.
I tried everything but nothing helped. Finally I canged to pins 8,9 instead. It worked perfectly at once. I don't understand why but I´m happy.
Thank you for your help.
