Building my own board for the propeller?
cbmeeks
I'm cheap and poor.
Considering I already have a lot of the supplies that come with the propstick, how difficult would it be to just buy the propeller chip and make my own board?
For example, I have a small breadboard (from RS) that I could devote to the prop. I would then need to get the eeprom, max3232 and the propeller.
What kind of problems would I be looking at? If it is too much, I will just shell out the extra $55 for the propstick.
Oh wait, I also have to consider that buying the extra pieces could run $10 - $20.
hmmmm.... :-/
cbmeeks
Metroid Classic:
http://metroidclassic.com
Metroid Forums:
http://eblarg.com/bbs/mc
DMCA Sucks
RIAA Sucks
hmmmm.... :-/
cbmeeks
Metroid Classic:
Metroid Forums:
DMCA Sucks
RIAA Sucks
http://forums.parallax.com/showthread.php?p=579595
This is the one that I made, seems to work well. Works with the USB2SER or the discrete programmer. Pretty cheap to build depending on how well your 'junk box' is stocked.
5 volt regulator feeding a 3 volt regulator, both TO-220.· The EEPROM and MAX3232 are both available from Digikey.· I haven't been pushing the layout because 3 boards would cost $59.00, no soldermask, no silkscreen.· If you would like one of the boards and I can find someone who would take the thkrd board, then I will press ahead with it.· If you are interested it would be best if you reviewed the layout before the boards are ordered.
Sid
Sid Weaver
Do you have a Stamp Tester yet?
Sid
Sid Weaver
Sid,
Has ExpressPCB changed their board size? I thought you could only use the Miniboard Service if the boards were exactly 2.5" x 3.8"
Post Edited (Mike Cook) : 5/23/2006 8:43:02 PM GMT
Sid
See the attached picture.· I opened up the bottom of the proto board and cut one of the links in the middle of one of the·long busses·to make two.· You can see the purple line above the crystal where I marked the dividing line betwen the busses.· The TO-220 regulator on the left powers the·left half that is the 5 volt buss and the TO-220 regulator on the right powers the top right 3.3 volt buss.· The bottom buss is Ground.· The four little prongs on the lower left are where the USB2SER plugs in.· This header comes with the USB2SER.· The two screw terminals on the upper left are where the 7.2 volt battery power comes in.· The two screw terms on the lower right is the composite video output.
The whole thing works great. And I am having a ball fooling around with it and experimenting with various Spin programs.·· I just love learning new stuff by rolling up my sleeves and digging in!
Stan Dobrowski
I did my board the same way, only a little neater, and everything but the chips and the xtal are held inplace with a small drop of hot glue.
Just tossing my two bits worth into the bit bucket
KK
Sid
Sid
Here is the link to the manufacturer's info: http://www.ecsxtal.com/pdf2/HC49U.PDF
Here is a link to the Digi-Key catalog page: http://dkc3.digikey.com/PDF/T062/0970.pdf
I'm not sure about the series/parallel spec, but the Digi-Key catalog page talks about it.
Stan Dobrowski
