Stamp Not Working
I have a BS2 USB that does not work at all. When running a program it simply says "stamp not found". I have checked that the stamp is plugged in, is on, I have the drivers installed, etc. Is it possible that it is fried and I am screwed?
csavage@parallax.com
9v battery still around 7v.
desk
No.
If you go into your "Device Manager" and click on "Ports" and then click on the USB to serial com port that is listed you will see a "Port Settings" tab, click on the "Port Settings" tab and then click on the "Advanced" button in the middle of the page and you should see a "Latency Timer" in the middle of the page.· We normally like to change it from 16 to 1·regarding timing issues.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
