VGA MODE for VGA_Demo.spin ?
I was able to use VGA_Demo.spin with my old sony triniton VGA monitor.
Now while on vacation, I am trying to use a LiteOn CM1565MCLR / Dell D1528-LS monitor,
it will not begin to display unless·I change to 21_000_000 hz vga_rate,
it is looks ok for a moment before the monitor recycles its startup.
Can this be used or is it pointless ?
What mode is originaly intended for VGA_Demo.spin
Full specifications are here http://support.dell.com/support/edocs/dta/65226/00000001.htm
Video Presets/Frequencies
Modes·· ·Resolution·· Horizontal·· Vertical
1·········· 720 x 400·· ·31.47 kHz·· ·70.08 Hz·
2·········· 640 x 480··· 31.47 kHz·· ·59.95 Hz
3·········· 800 x 600··· 46.87 kHz·· ·75 Hz
4········· ·640 x 480··· 37.5 kHz···· ·75 Hz
5·········· 640 x 480··· 37.86 kHz· · 72.81 Hz
6·········· 800 x 600··· 37.88 kHz·· ·60.32 Hz
7·········· 800 x 600·· ·48.08 kHz··· 72.01 Hz
8·········1024 x 768·· · 48.36 kHz·· 60 Hz
9········ 1024 x 768··· ·56.48 kHz·· 70.07 Hz
10······ 1024 x 768··· ·60.02 kHz·· 75.03 Hz
11······ 1280 x 1024· ·64.34 kHz··· 60 Hz
2·········· 640 x 480··· 31.47 kHz·· ·59.95 Hz· THIS IS THE MODE!!
Chip Gracey
I hate to ask this question but doesn't this imply that the Rev C Demo Board would support VGA better with the 6Mhz crystal?
I suppose I could easily remove the 5Mhz and install a socket to that end.
But it seems obvious that I would be overclocking unnecessarily high.
Maybe there is a 5.10Mhz Xtal or closer out there.
I beleve the program makes some funny calculations with 21_000_000 and this just happens to get the problem monitor to turn on with a display.
The VGA monitor is going through several of it's vga modes to try and lock on and after 10-15 seconds it locks up and goes in to powersaving mode.
I think that the problem is more one of a fussy monitor than changing the XTAL, since my old Sony monitor works fine and the problem monitor works ok with my laptop.
I am now using TV output so I am not concerned now.
Then the next day Chip Gracey released the vastly improved vga_text_demo.spin in the archive·'vga_text_demo - Archive· [noparse][[/noparse]Date 2006[noparse][[/noparse]1].05.17· Time 02.32]' this one has much the same timings as I had changed to and worked beautifully for me too.
Where can I find this "new and improved" vga-object that has better timing ?
I tried to look in the object exchange but it was not there .
pointers ?
petri.
Terve! Olen illoinen ett
Pekka·sanoi tuntevansa sut ja kertoi hauskoja tarinoita niiltä ajoilta.
Hän myös lupasi mulle pullat ja kahvit jos saan VGA:n ruudulle jotain järkevää alle kahden viikon...
Taidanpa piipahtaa tampereella loppuviikosta lunastamassa lupauksen
Hän voisi varmaan ottaa propellerit edustukseen jahka näkee ensin yhden toiminnassa.
Thank You·Chip,
I appreciate your extremely quick response (... and the objects of course)
I'll give them a spin (
Being an active PIC-programmer (CCS C) I just can't tell you how much I appreciate the
quick and painless development cycle associated with the propeller.
Great product.
regards,
petri.
So I tried the new objects and got the same results, just different looking unsupported rates this time.
(I'm am using Hitachi CM766ET monitor, and it should support quite a few modes)
So I thought I make sure:
1. I've built my vga-circuit according to Propeller Demo Board Rev B
Should I use rev C ?, where do I get that picture from ?
2. Is the vga-connector documented so that the "holes" in the female connector are facing the viewer ?
3. I left out the yellow leds and their 240ohm resistors , could that have an impact ?
4. has someone actually made this work outside parallax offices ?
hmm ... hoped that this would be easier.
petri.
2. use the pin markings on your connector (should be shown)
3. no problem
4. built mine on a bit of perfboard, plugs in perfectly with my propstick on a breadboard, will post a pic if that would be useful
edit: looking into the female vga the pins are
5........1
10.....6
15.....11
Who says you have to have knowledge to use it?
I've killed a fly with my bare mind.
Post Edited (CJ) : 6/20/2006 2:45:29 PM GMT
http://www.tkk.fi/Misc/Electronics/faq/vga2rgb/calc_v15.html
Chip Gracey
I checked my LM2937ET with scope and it produces a really nice and clean 3.3 V
btw, I am trying to use the 640x480 mode.
There is something really funny going at at the horizontal sync.
When magnified I see that there are about 1.8 us negative pulses about 28 us apart,
but there's a huge ripple that fluctuates a lot.
see attached 3gp-video (if you have tools for viewing it, I was not able to convert it to anything else)
In fact I'm not too crazy about the ripple in the vertical sync as well.
See attached jpg
CJ , it would be really nice if you could post a picture of your setup .
I'm pretty sure this just some funny (not actually so funny anymore) cockup on my behalf
and maybe comparing to your functioning one would help me to identify the problem in mine.
regards,
petri.
the last connection on the right is ground and is connected per the schematic, also lines up perfectly with the propstick ground in a breadboard. hot-melt glue is used with zeal to attach the port and to prevent shorts
GOT IT !
GOT IT !
thanks CJ.
I rechecked everything once more and found out that my VGA connector
had a broken pin 14, so the sync never got to the monitor.
I changed the connector and voila ... everything works fine
and I am happy as a pig in (expletive).
This is soooo coool.
thanks,
petri.
