assigning 4 seperate leds from 1 output pin
In experiment three of the stampworks book,4 leds flash at the same time. I want to make the leds work seperatley, but they all work at the same time, even though I assigned each pin seperatly in the programming.·Is this because of the way the breadboard is conneted, or does each led need·a seperate output pin from the bs2 stamp?
OS-X: because making Unix user-friendly was easier than debugging Windows
