Having trouble interfacing PropSTICK & PDB's LCD
I'm trying to get my PropSTICK to talk to the parallel LCD through the connector on the Professional Development Board. I started with Jon's Serial LCD object and modified it for the parallel LCD.
I put 10k resistors between all of the PropSTICK pins and the LCD header. I think I've got the code doing what I want. I've checked the E, RS, and data pins with a 'scope and they're all behaving the way I expect, but the LCD isn't responding. Is this a 5V vs. 3.3V problem or am I doing something else wrong?
OS-X: because making Unix user-friendly was easier than debugging Windows
·· Jeff Martin has successfully interfaced to the Parallel LCDs of many sizes and brands including 4X40 (dual-controllers).· I think he even had 22K resistors so I doubt that's the issue.
csavage@parallax.com
Then it was just the small matter of having the most significant bit/least significant bit backward in my outa[noparse][[/noparse]DB7Pin..DB4Pin] statements and now everything's working perfectly.
Edit: Attached program
Post Edited (SSteve) : 5/21/2006 4:39:39 PM GMT
I just wanted to confirm that you are NOT using resistors on the E, RW, & RS and that you are using 10,000 ohm resistors on the 4 data pins.
Also, I presume that the posted Object is working now.
I have several parallel LCDs and only one [noparse][[/noparse]not Parallax Serial LCD], so I really would like to impliment this object.
The nice thing about OOP seems to be that these objects are a lot easier to share than a whole application and/or snippets in PBasic.
The posted version is working great in a few quick tests. Let me know if you have any problems.
You're right. With OOP it is much easier to share useful code. Since it's a self-contained entity, you only need to know how it interfaces--you don't have to figure out how to merge lines of new code with lines of code you've already written. It's also easier to modify existing code. Ninety percent of the code I posted is the serial version that Jon wrote. I only had to change a few methods to get it to work with the parallel LCD.
·· Tomorrow I will check with Jeff on the connections he used.· Often with the Propeller you will need some resistor on control lines like that since some are internally pulled high.· I will check into this further though.
·· I spoke with Jeff just now who is desperately trying to fill the need for more documentation.· He used 2.2K resistors on all 8 data lines when connecting his LCDs.· The only other resistor he used was a 10K pull-down on the Enable line.· Other than the data lines, the other lines were connected directly.· If you were using write only mode as is often done on the BASIC Stamp you could ground the R/W line and not have to have the 2.2K resistors.· I wouldn't recommend this though.· The Propeller is so fast and with an LCD object running in another COG you could write extremely fast by reading the BUSY Flag and sending data as fast as the LCD can accept it.
·· I just noticed your object is working in 4-bit mode.· You can get a substantial speed increase using 8-bit mode, and the Propeller certainly has the I/O for it.
I have projects growing like mushrooms and in need of output display. For now, this will save me having to construct Serial to LCD from SX18s that I have set aside.
I still prefer the serial interface as the Parallel just consumes 7 to 11 pins of the Propeller. I guess if you don't need them it is okay.
