I would like to hook up my project in between a car's ECM and injectors, to count the pulses.· I wander how much bounce or noise the ecm has controlling the injectors?
How much noise does an animal make when you give it a bath? How about the make model and year of the vehicle? You will probably need something in the circuit to condition the output of the ECM.
You will find quite a bit of noise in the injector driver circuit.This is mainly because the injectors are solenoids,coils that induce stray currents at a sometimes problematic level.
The on board ECM is made to filter out the trash.
The safest route to pull a signal from the line might be with an optocoupler.
- Stephen
Good Luck, Jim Richey
Thanks, Parallax!
