Solar powered robot.
Hello.· I was wondering if it's posible to create a solar-powered robot.· You could have it charge the main battery wile it roams and if the light goes away it would continue to roam.· The lowest power supply for the boe bot is 6 volts, I've seen panels that generate 6 volts.· Can this be done?
There is always an answer.
There is always a way.
There is always a reason.··· -SciTech02.
www.solarbotics.com/
So many hobbies, So little time.......and money [noparse]:)[/noparse]
Most of their bots exibit 'insect' like behavior- It is a different type of robotics- for some it will not give the movement/feedback they expect a robot to have (like say, a BOEbot)- it can be interesting to see their bots' behavior imitate insects, albeit generally much more slowly.
Ryan
Ryan Clarke
RClarke@Parallax.com
So you'll either need a much larger solar cell area, or use the cell to 'recharge' the bot, or only be able to move the 'bot' short distances, then wait for a long while for the solar cell to recharge the batteries to a 'useful' level again.
In fact, that's what they do on Mars at this point, for their 'rover' vehicles. Sit and charge the batteries, then move a little, take a picture, then sit and charge the batteries some more.
If you dream of things like radio communication, internal navigation, vision and speech; it really won't happen with purely solar power. Solar recharging may be useful in some instances and if you use lithium polymer batteries you can get a significant reduction in weight.
In other words, try to consider the kind of robot you want rather than intially defining it by this particular power source.
I still dream of a five legged, omni directional beast, but I have yet to commit to building it as I suspect I would want 3 servos on each leg - maybe four.
I am working on building a Solarpowered BOE bot, I'll let you all know how it goes.
Ryan
Ryan Clarke
