BS2px, BS2, and prop. vision capabilities
What is the best processing job each one of these can do? The BS2 is probably limited to a CMU Cam, and can the px do a CMU Cam 2? And can a propellor process a serial webcam? What about a USB to serial adapter, hooking the web-cam and the propellor?
thanks,
ACfishing
thanks,
ACfishing
·Somebody said...
-Never Underestimate the power of human stupidity.
There is always an answer.
There is always a way.
There is always a reason.··· -SciTech02.
Where can you find a serial-port Webcam?
(I've never seen one)
I guess the Propeller should be able to process at least some of the data from it.
Don't visit my new website...
http://froogle.google.com/froogle_cluster?q=serial+Webcam&pid=4712140183881044120&oid=2232322337849192327&btnG=Search+Froogle&ei=NvluRIXhL6LYqwLQ1pG8Dg&sig2=8KCBGe9wsOVD-8eK5PAEVw&scoring=mrd&hl=en
a MAC one:
I hope those both might work.
I'm trying to achieve simple vision, like following a line, with a webcam
(TCP/IP 'Point to Point Protocol')
Your best bet is probably to go for a CMU-cam, or if you could find one, an old Nintendo Gameboy Camera and hack that.
Another possibility, depending on the resolution needed, and space available, is to put together a matrix of LDRs, Photodiodes or PhotoTransistors, and put a lens in front of them.
(The smallest LDRs I have has a diameter of about 5mm, but with 1206-size SMT Photodiodes... In fact, I'm making a note to order a few the next time I shop for components)
I did find something interesting over at Sparkfun, a 640x480 CMOS camera designed for use in cellphones.
http://www.sparkfun.com/commerce/product_info.php?products_id=637
It's only $20 (add another $ for the connector) so it's no big loss if it can't be used...
The only problem is that they don't have the documentation for it, only a few docs for similar chips.
I've ordered one, but have no idea of when I'll get a chance to look at it and experiment.
(I'm about buy an apartment in a building that I'll have to help build, so...)
-phar
