stamp not downloading code :shocked:
when i try downloading the code onto the stamp, the program says it sees the stamp but it cannot download program onto stamp and to check power supply. i checked my 9v battery and it is running at 8.6v. mabey it has something to do with using a 9 pin serial to usb adaptor or the length of the cable. i dont know. i am new to electronics. can anyone give me any leads?
Post Edited By Moderator (Chris Savage (Parallax)) : 5/18/2006 6:22:37 PM GMT
csavage@parallax.com
the adaptor i used is called a usb pda/ serial adaptor cable made by dynex. it says that it works with devices that have rs-232 interface and that it supports data transfer rate up to 500 kbps. all greek to me.
Post Edited By Moderator (Chris Savage (Parallax)) : 5/19/2006 3:04:48 AM GMT
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
This is the driver with the idotConnect USB-Serial Cable (by PPA Int'l)
Does anyone know if this will work?
So far, it doesn't appear to allow me to download code to the BASIC Stamp, but I am now sure how to know if there is some other problem or if this is it.
Thus the recommendation for the Radio Shack, and FTDI, (and the Keyspan 19w), all of which have been proven to work properly. And it's not a problem with the BS2, it's a problem with cheapo companies that take too many shortcuts when they make their USB adapters.
In case anyone is curious, this driver and cable does work! (and it is only $15 at Fry's)
·· Does it work on many different systems, including Laptops and Desktops?· We extensively tested a few adapters and some will work on a few selected machines, but not all.
I had the same problem and I bought the $15 cable at Fry's. After i loaded the drivers, I had great success. SAME PROBLEM----SAME SOLUTION just a couple of days before you did!
