PropStick Board
I am trying to·make a board to hold the PropStick.· Are there any pins, such as the Tx/Rx or SCA/SCL lines that should be hardwired pullup or pulldown.· I'm planning jumpers for P0-P7 so they can be pulled HIGH or LOW.
Sid
Sid Weaver
Do you have a Stamp Tester yet?
Sid
Sid Weaver
·· The PropSTICK is really designed for breadboarding.· And it's a great solution for that.· If you really want to create your own PCB you should just use the DIP version of the Propeller chip and mount it directly into your board.· This way you're in control of and know what's doing what.· Everything is pretty straight forward on the PropSTICK but it in and of itself is a PCB encapsulation of the Propeller Chip.· I guess I can't see mounting it on another custom PCB.· If I were to do that I would simply accomodate the DIP Propeller directly.
csavage@parallax.com
Please consider keeping the PropSTICK intact for what it was intended as it will become more and more useful as more code and applications evolve.
Like many, I have made my own board to save a bit of money.
The main drawback is that you have to either build another programing interface or use a USB2SER.
It certainly isn't as compact as the PropSTICK either [noparse][[/noparse]at least 3 times larger] and has some shortcomings.
The PropSTICK already has 4.7K ohm pullups on the I2C bus that are intended for having more I2C chips use the bus.
And the Tx and Rx are intended to be used as a regular RS-232 port; not merely a programing port.
My board needs more modification for the RS-232 to be useful for other than programing as I couldn't get the MAX3232 chips.
So I hope you begin to see that the real beauty of the design is that no additional board is required.
If you want to build some more, start from scratch.
Post Edited (Kramer) : 5/18/2006 4:57:27 PM GMT
Who says you have to have knowledge to use it?
I've killed a fly with my bare mind.
It was not my intent to alter the architecture of the PropStick.· I just want a socket on a board that I could plug it into.· That way I could have the I/O pins coming to headers or screw terminals.· I also wanted to add a pullup/pulldown option on Pins P0-P7.· Unfortunately I could only do that for Pins P0-P3 since I can only make single-sided boards on my little SuperMill.
Sid
Sid Weaver
it has the 40 dip socket, female headers in the rows next to the socket so that the label on the propstick works as it should, and breadboards all around
·· Even if you cannot make a double-sided board, you could make a single-sided board which has a 40-pin socket, 3.3V regulator and your pullups.· It could also hold the EEPROM and header for programming it using a USB2SER.· In any event if done carefully this could be done on a single sided board with few or no jumpers.
Sid
·· I was actually referring to a 4-pin header like the SX-Key plugs into that you would instead plug the USB2SER into, but I suppose you could implement the Serial Interface on that board as well.· Or you could use the PropSTICK.· The choice is yours.·
Sid
Sid
Sid,
·· I think you are thinking of the USB to Serial Adapter we carry.· The tool I refer to is linked below.· This was how we originally programmed the Propeller Chips.
http://www.parallax.com/detail.asp?product_id=28024
Sid
