PIC16C57-20p
I ordered three pic16c57 chips from mouser electronics trying to go cheap. I found out that they were not preprogramed with the basic interpreter. What can I do with these chips? Can you guys program them for me? If so what are the conditions?
Jon Williams
Life is one big road with lots of signs. So when you're riding through the road don't you complicate your mind.
Bob Nestor Marley(Berhain Sellasie)
On the good side, I don't think an un-programmed 16C57 is very expensive, so you haven't lost much. On the other good side, the programmed interpreter chip is like $29 or so, so you'll still have a 'cheaper' BS2 than the module.
And note the 16C57 DOES have a 'protect' fuse, so you can't copy the Parallax run-time from it to another 16C57.
P.S. as corrected below, the Interpreter chip is only $11 in single quanties.· Wow, such a deal!
Post Edited (allanlane5) : 5/18/2006 1:34:58 PM GMT
http://www.parallax.com/detail.asp?product_id=PBASIC2C/P
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
